Im just trying out rendering with aces, so im presuming ive broken something
This is rendering in GPU rtx,
I have the ACES 1.2 config set, with correct settings in VFB. When i render with lightmix, you can see the light source, that is white..is rendering green. Also if you look at the attached video, you can see some weird stuff going on when its rendering.
I’ve attached the scene. Maya 2022, latest Vray 5 release.
Low and behold, in cpu mode it looks fine.
lightmix.zip (1.41 MB)
lightmix_scene.zip (1.19 MB)
ok so ive shared another video and scene here. (GPU RENDER)
https://drive.google.com/drive/folde…WB?usp=sharing
I dont know what the hell is going on but its doing my head in…
When i render with lightmix for some reason, the selected rectangle light is contributing to its own channel but only green light,
but also in the the ‘REST’ channel…
If i then go and delete one of the other lights in the scene, and re render, it works as expected, the original rectangle light no longer contributes to the Rest channel and is the correct color…you have to look at the video to see what i mean.
I dont know why, what i did or anything…the only thing i can think of is that im cursed
Hey @francomanko ,
The good news is, you’re not cursed. And this has nothing to do with the ACES/Color Management settings (it also happens if we remove the ocio config).
This only seems to happen if Cryptomatte RE is added. If we remove it, all should be fine - you can check on your end as well. Looks like it’s fixed in the latest nightly builds, so hopefully it should be out soon. Thanks for the pointer
