Lightmix and general VFB2 questions - single render, mutliple users
Hi Guys
1) Am I correct in thinking all this functionaluty is automatically saved into the history (as vrimg files), if you have the relevant render elements added before render?
2) Can another user, from a blank max scene, load the vrimg file from point1 into the VFB2 on their system, make adjustments, and resave that vrimg?
3) Can the 1st user, then in his max scene, reload the saved vrimg from point2, and apply the lightmix settings that was adjusted in point2, back into his scene?
4) Does it have to be vrimg file, or can it be multichannel exr (or even separate split exr)?
1,2,3 - Yes you are right for those. For step 3 - the lights in the light mix and the scene must fully match for the transfer back.
4) For now it must a single file - vrimg or multichannel exr.
Yavor
Great, thanks Yavor
