Lightmix bug when first opening scenes
Hey
We have an issue where lightmix won’t kick in, when we first open a scene and do an interactive render.
We have to tick off a lightmix layer then on again for it to work.
This happens 100% of the time when using multiple HDRI’s in lightmix.
Corona version: 12 (Hotfix 1)
Full-speed, Non-debug, MaxSDK 2024
Edition Windows 10 Enterprise
Version 22H2
Installed on ‎28-‎05-‎2024
OS build 19045.5131
Experience Windows Feature Experience Pack 1000.19060.1000.0
Do you mean when selecting lightmix render element, it is not displaying what lightmix layers are setup to show, and you need a single enable-disable of some layer for it to show the expected result?
Exactly. Yes.
Thanks.
Please create a very simple scene where this can be reproduced easily, and send it over. A video recording will be even better and make things quicker.
We will investigate it surely.
Found the reason why. When opening, corona defaults to the beauty pass. It goes to the lightmix pass once you tick off and on a lightmix layer. So when you do a render after closing corona, what you see is different.
If you open the scene, start rendering, and then go to Lightmix, without editing any lightmix related thing, it should show correctly what lightmix element is supposed to show. There should not be a need to turn on/off anything to properly display the lightmix element. If you open the scene, start rendering, go to lightmix and it is not showing the proper lightmix, then it is a bug.
VFB defaults to beauty at the first render after opening the scene - I think this is better than displaying lightmix, as beauty is the actual render, lightmix is an element, like alpha or zdepth.
