Hi
Had a couple of LightMix configurations saved so I could load them based on camera shot etc. Worked great. Only problem came when I deleted a LightSelect render element in the middle of the stack (I had 15 LightSelect elements).
After having deleted this, I later loaded the LightMix config and got a totally different looking image.
It was clear that the config file remembers each LightSelect element’s value based on how that element is placed in the render elements list and NOT pr each unique render element.
So basically, by deleting my number 2 LightSelect element and then loading in the config file, all the other elements got “moved up” on the list and received wrong values.
Example:
Lightmix config:
- Lightselect Light Table = 1.0
- Lightselect Light Spots = 0.8
- Lightselect Light Sofa = 2.0
- Lightselect Light Door = 0.5
- Lightselect Light Hall = 0.3
I then delete my lightselect element called “Light Spots”, load my config and I get this result:
- Lightselect Light Sofa = 0.8 (should have been 2.0)
- Lightselect Light Door = 2.0 (should have been 0.5)
- Lightselect Light Hall = 0.5 (should have been 0.3)
I don’t know if a each render element has a unique ID and the value could be tied to that, so even a name change on that element wouldn’t mess this up.
Build was the 11-01-2017 daily on max 2016.
