I haven’t been using LightMix in production until recently. But I have a huge problem on a current project where I get constant crashes when rendering Light mix.
I have just a few lights in the scene + hdri.
I’m rendering 4K. I’m using Takes. File is approx 1.2GB of size.
When I turn off the denoising everything works fine.
Any ideas on what could be the problem?
Could it be the ram? I only have 64GB.
Thanks.
Matej
Well, denoising does consume some extra… observe RAM consumption (in task manager). See, if other options, i.e. “save data for later…” do any better.
More on: “How to use denoising in Corona for Cinema 4D?”
BTW, you could also render via command line to use less RAM.
Thank you @burnin!
Save data for later seems to work great, no crashes.
Btw. how can I render via command line?
Neat! Glad it has resolved your issue.
Now, here’s “How to use commandline rendering in Corona for Cinema 4D?”
Be well. (:
