LIGHTMIX Instance lights on same layer
Would be great corona put all the instanced lights inside the same LAYER wuen using the setup button, since if you get the lights instanced you probably need all on the same values and speed the process of configure the lightmix
Duplicate: Renderer for architectural visualization - Corona | Chaos
Great a group with all lights inside.
LightMix Automatic button will create only one layer.
sure, there are drawbacks as everywhere but if a scene is as simple (one instance of lights) you may not need some automatic creation anyway. And if you want to control the lights seperately they would be unique and not instanced. Also think about the upcomming “put to scene” feature.
Good Luck
