Lightmix not Showing on CXR
Hi, i have rendered my scene with lightmix settings in it. But after i saved it as .CXR when i open the file in corona image editor under lightmix tab. Its saying Lightmix is not available. You need to add at least one LightSelect and one Lightmix render element while rendering the image in Corona Rendered.
I have 1 lightmix and 5 lightselect under render elements when i render the scene but after saving it as .cxr doesnt recongised lightmix settings.
Im using3dsmax 2018, Corona 1.7 Hotfix 4
Any help? Thanks
Hi. You have to choose the “Save All” option or Save CXR.
Hi, what CIE version do you have? Is it from Corona v1.7.4? Please, can you share the CXR (and scene, if possible) so we can investigate it? You can use our private uploader for that. Thanks.
