When I bring in my multilayered exr into After Effects the beauty pass looks exactly the same as in the VFB, but when i split the light mix elements and add them together they appear a little darker because it has removed the exposure setting i added. any way to keep this in light mix?
Hi what exposure setting are you referring to? Do you mean the “All” layer in the light mix?
The adjustments to the lighting done in LightMix can not be implemented to the render elements after rendering. You can use the “to scene” button:
Once you are happy with the lightmix hit “to scene” and render again.
