Lightning In A Glass Sphere
This may have been covered before but I haven’t been able to find any info.
I have created a hollow sphere, with the Shell command. Then I added a renderable spline in the sphere. Now I go to Video Post and setup for Lens Effects Glow on the Object ID channel of the spline. Click on the render button in Video Post. The render window opens and I see it being rendered. When it gets to the point of doing the glow effect I get “An Error Has Occurred and the Application Will Close.”
I assume it is a conflict between VRay and max’s Video Post. I am running max 6 SP1 and VRay Adv. 1.09.03r. Is there any way of doing the old lightning in a bottle trick?
Thanks in advance.
JoeD
Enable the proper g-buffers in the renderer.
Thanks for that info. I did apply what you said and the error is gone but I still don’t see the glow effect in the sphere but the same object outside the sphere does.
Any advice?
JoeD
does it work in scanline? i thought glows etc didnt work behind transparent objects since the z-buffer doesnt trace through objects.
Would be easier to do and tweak in post anyway
yeah that has always been a problem. I remember a plugin awhile back that would allow you to do it. cant recall the name though. It was commercial.
percy
It does work in the scanline mode if I use the Material Effects Channel. But in VRay I don’t get a choice of G-Buffer parameters to link to the Material Effects Channel. If there is NO sphere using the Object ID in VP and the Node ID in VRay you do get the glow effect.
Oh well, foiled again by that little girl and her dog.
Thanks for the help.
JoeD
Not sure if they work with VRay but you can try the “Ce Thru” or “Transparent_ID” Render Effect plugins.
--Jon
I took a look for those plugins but I couldn’t find them in max 6.
JoeD
As far as I know, the only way to get an object to glow behind a glass object is by using a raytraced material for the glass. I haven’t tried with VRay.
-Matt
