Hello, I have attempted to look through the forums in a search to find a solution to my problem. I am setting up corona lights in 3ds max to be used in the render, but, when I render, the light models also, unintentionally, show up in the render. I have attached a screenshot of the lighting setup in the viewport as well as the final render. I was wondering if there was a quick fix to this issue?
Look at CoronLight properties in command panel>modify tab. You will find there nonphysical properties rollout, it has bunch of visibility switches, i think you’ll figure it out what they do :]
