add a lights statistic feature to the V-Ray Profiler. It would be very helpful to analyze how much each light contributes to render times. This would make debugging very complex scenes much easier.
Submitted on AHA Ideas (VRAYMAX-I-94).
Status: declined
Can you explain a workflow that includes such information? What would you like to do with the statistics? Can you describe a specific use case?
Submitted on AHA Ideas.
Hi. Sure, For example in the scene with 1000 light, some of them instanced, some of them Self-illumination materials, and sometemies some light can cause long render due their amount/size/shadow bias and etc. So it would be good to check similar like with material how much time spend on particular light (instanced for example like in Light mix) to understand, if this light took to long to render, but we know that it’s not have big impact in the scene, we can just turn it off or optimize in some way
Hi. What would be this way?
What do you mean by- if this light took too long to render? The factors for slower rendering could be due to rays getting through some more complex materials.
Yes, that might be one of the issues. By combining information about how many samples are spent on a particular light with detailed material data, we could identify which material/light combination is producing noise. For instance, if a stock model has a complex material interacting with a specific light source, it might generate noticeable noise and in a large scene it can hard to find what exatcly produce noise. Having access to both material and lighting statistics could help us pinpoint the “bad guy” more easily.
On a related note, would it be possible to include statistics on how much of the image area each material occupies? For example, if the V-Ray Profiler indicates that 30% of the render time is taken by a single material (like water), we can understand why it might take longer to render compared to other materials. Providing an indication of the image coverage per material could give us a more complete picture and help in troubleshooting rendering issues, or not if we will see that it take a lot of space in the final render
Hi, about the second question. Have you tried to use VRaySampleRate (https://docs.chaos.com/display/VMAX/VRaySampleRate) ?
It doesn’t show the percentage, but you have a direct indication of areas that could create noise, respectively being slower to reach the desired quality.
hi, yes I tried, it show the aread, I just thought maybe yo brak it more to components, to see what affect on what (light, materials)
Hi. Thanks. I will check more in detail about the lights. But keep in mind that the topic is quite complex. We have adaptive lights, we have a cutoff on the lights, etc. A lot of factors could affect such a calculation.
Light is a complicated matter and it would be hard to isolate the effect only coming from lights, and not taking into account other factors in order to create a visual representation in a profiler. We will keep in mind your needs but for now, this idea will be declined.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
