Was the behavior of the texture paths changed? I was looking why some lights stopped working and I noticed that were we used to have to use “op: path_to_texture”, those textures were not working anymore, instead it now works without “op:”. Was this intended?
Best,
David.
Nothing have changed in that regard, we use standard Houdini SDK methods to resolve paths.
Hi @david.anastacio , I can’t reproduce the problem with “op:”, could you send me a scene with it, it can contain only one light with the expression you are using. Upload it here ,or send it to georgy.chakarov@chaosgroup.com. Thanks!
Yeah this is very strange indeed.
So we had here a bunch of shots/assest with the “op:/” path in lights that suddenly were not working. But I was testing in a clean scene and it seems to be working, I’m trying to figure out what is wrong on the production scenes now…
Thanks for checking on your side too @bdancer and @chakarov , I’ll let you know.
Best,
David.
Ok, I think the chage was actually in Houdini, maybe when we changed from 18.0.287 to 18.0.397. The texture paths didn’t work without the “op:” before the path to node, but now you don’t need to use it anymore.
Also the lights that stopped working were a path issue, a “/” was added were it should,t, sorry about that,
Best,
David.
