Lights turning on and off
Hi all. My lights are turning off.
This is my 2nd attempt (I’ve turned off adaptive light solver)
Any more ideas what I can do to have them not flicker on and off?
I don’t think the light are turning on or off, but their reflection appears to be changing.
I would advise resetting the render settings, and making sure you are rendering with settings which are best for animation:
https://support.chaos.com/hc/en-us/articles/4528617365649-How-to-use-the-UHD-Cache-for-animations-and-stills-in-Corona-for-3ds-Max-
The flickering can also depend on the lighting setup - if there are fakes or obscured light sources (including Z-fighting), it can cause such flickering.
Hi.
We’ve rendered hundreds of animation so know how do them.
In the past turning off adaptive light solver has fixed this issue.
I think I fixed this shot by doing a number of things - I’m not sure which one did the trick.
There are a lot more server rooms so I un-instanced the bottom lights which aren’t seen and turned them off
I also changed the light sampling to Precise
All of the other shots have rendered absolutely fine so yes, I can only assume the lights are causing it
Glad to hear the issue is solved.
Sorry if my initial reply sounded with a presumption that you are not familiar with the animations settings. But in case of flickering in animation making sure the secondary cache is set up correctly is the first thing.
It does really look like Z-fighting or related issue, so probably the light setup tweak did the trick.
