so if i understand this correctly, a scene can be lit by:
1. a vray light
2. a vray light that can use any mesh as the light
3. a mesh that has a vrayLight material applied to it - GI only or with Direct Illumination turned on (it becomes a mesh light?)
if you want to get rid of jaggied edges on lights
1. you can only use a vray light - non-mesh - with softbox map
also when i was playing around with vraylight material with direct illumination turned on, it does not behave as direct illumination if the material is part of a multi-sub object.
