Limit round edges to specific objects
Is it possible to limite the round edge shader, to take some objects into account not all objects?
You can enable by object under Attributes>Round Edges
Thanks for the reply damaggio. You’re right in that this does enable round edges for individual objects. However it does not allow us to exclude certain objects
Just don’t apply round edges to those objects.
You can use this script to set Round corner to a bunch of objects at once…
string $selection[] = `ls -sl -dag -lf`; // remember all Shapenodes in selection
for ($node in $selection)
vray addAttributesFromGroup $node vray_roundedges 1;
vrayAddAttr $node vrayRoundEdges;
vrayAddAttr $node vrayRoundEdgesRadius; // 3 lines add Vray arrtibutes
setAttr ( $node + “.vrayRoundEdgesRadius”) 0.12; // Set it to 0.12
