there is a limitation / bug in some material chain :
Put a glass CoronaLegacyMtl into a CoronaLayered, into a Multi/sub material slot ID2
Put the first glass material in the multi/Sub slot ID1
It works well until we set absorption color and distance in volumetric scattering
Here is a video that shows the problem. And the max scene
The absorption is not good, as the ID2 face is no more transparent, as if light was goning inside but not outside the box.
With refraction color it is ok, but i never use it, as absorption color is far away better as it takes in consideration the thickness of glass.
using refraction color instead of absorption, it seams to work, but we can see that refraction is not good (see attached), it seams that refraction is faking more thickness… So with absorption, of course, it is very dark, as if the distance were not enough.
This is expected and it is a “spin-off” for physically accurate rendering.
You are effectively applying a volumetric material (with absorption) to a single plane, which is not an enclosed volume.
You can see that this is in fact the case by detaching the single polygon and moving it a bit away.
I would also argue that the best way of doing this is by decal, which works absolutely fine and more intuitively.
Yes, it was not detached, I just detached it to make it clear what happens - even if the polygon was not detached on model level, having a different material on it acts as if it was detached material/medium resolution wise.
