Limited Maxscript Properties in V-Ray GPU
When i showproperties for Vray GPU I get a small fraction of what I do with V-Ray standard. I need to change the VFB output filepath/filenames through maxscript but can only access those functions outside of GPU. Is there an issue with my install?
Here’s my output:
V_Ray_GPU_Next__update_3_2:V_Ray_GPU_Next__update_ 3_2
.rt_settings_ui_view : integer
.traceDepth : integer
.gi : boolean
.gi_depth : integer
.cpu_bundleSize : integer
.cpu_raysPerPixel : integer
.progressive_raysPerPixel : boolean
.coherentTracing : boolean
.lowGPUThreadPriority (Low_GPU_thread_priority) : boolean
.undersampling : integer
.showStatistics : boolean
.aa_showMask : boolean
.aa_threshold : float
.overrideMtl_on : boolean
.overrideMtl_mtl : material
.overrideMtl_excl_type (overrideMtl_ExclType) : integer
.overrideMtl_excl_objectIDs : string
.overrideMtl_excl_layers : string array
.vrscene_on : boolean
.vrscene_fileName : filename
.vrscene_dontRender : boolean
.max_render_time : float
.max_paths_per_pixel : integer
.sampler_type : integer
.stereo_type : integer
.output_layout : integer
.stereo_swapLR : boolean
.stereo_eye_distance : worldUnits
.stereo_focus : integer
.geometry_proxies : boolean
.geometry_xrefs : boolean
.geometry_particles : boolean
.geometry_displacement : boolean
.geometry_motionBlur : boolean
.engine_type : integer
.opencl_textureSize : integer
.opencl_resizeTextures : integer
.opencl_textureFormat : integer
.opencl_bundleSize : integer
.opencl_raysPerPixel : integer
.bundleSize : integer
.raysPerPixel : integer
.ipr_raysPerPixel (iprRaysPerPixel) : integer
.distributed_rendering : boolean
.inproc_rendering (In_process_rendering) : boolean
.warn_unsupported : boolean
.warn_nonPhysical : boolean
.msg_delay : float
.autoupdate_bitmaps : boolean
.use_32bit_buffer (Use_32_bit_frame_buffer) : boolean
.top_merge_angle : angle
.bottom_merge_angle : angle
.pole_merge_method : integer
.stereo_followHeadset (Follow_VR_headset) : boolean
.fitToVFB (fit_to_vfb) : boolean
.enable_cpu_interop : boolean
.filter_size : float
.ipr_forceBruteForceGI : boolean
.vrControllerLTouch : Interface
.vrControllerRTouch : Interface
.vrControllerRemote : Interface
.vrControllerXBox : Interface
.V_Ray_settings
Hi the parameters that V-Ray GPU shares with V-Ray are grouped in the .V_Ray_settings property. showproperties yourVRayGPUinstance.V_Ray_settings would reveal them.
Alexander
