LINE LIGHT LEAK THROUGH THE OBJECT
Hi…everyone!
I have a problem about light leaking.
Even I go for the ULTRA render.
And I also try making a lot of ‘wall’ to block it but it doesn’t works.
But if getting closer the leaking will gone.
I know it’s a bug that the distance between the light source and view.
And I already updated to the latest Enscape 3.5.
Have any idea to slove this problem???
WITHOUT THE LINE LIGHT SOURCE IT WILL LOOKS LIKE THIS.
I have this problem frequently, since my designed spaces are also quite large and have a lot of light sources. I ended up just removing some “unnecessary” light sources as a workaround.
Here’s my post about it from a while back:
RE: Artificial light is popping in/out (off and on?) as I move around
Can you share that model or part of it?
I think I just fixed it!
I just delete “unnecessary” light sources and object around.
Thanks @Tim_3 btw.
