Linear Light Inside Symbol dont work
i assume this is a bug or a not completely implemented feature regarding Light Sources/Linear Lights inside symbols.
Doing this with Spotlights etc. seems to work as it should.
But if Linear Lights and Area Lights are inserted inside symbols the wont show up anymore.
they only show up properly if they are inserted in groups or “raw”.
Are you aware of this problem/already planned to fix?
Thank you
Greetings
Also there seems like an limitation with the length and shape of a linear light.
As soon as the line of the lights source has
  • More than 2 corners
  • round corners
  • Start and Endpoint longer than around 4 meters apart
it won t show up anymore in Enscape.
