linear = none
This article states:
“Note that in most cases the normal map bitmap color space should be set to Linear to ensure correct results.​”
But the UI of V-ray in SketchUp has been reworded “Transfer Function” = “None”
I was searching for a half our before I found it had been renamed…
Hey @marthamaatkamp ,
Thanks for spotting this and reporting it here!
You are right, it’s called Transfer Function and it should be set to None. I corrected the page.
Cheers,
Kristin
