Liquid Dynamisc question
Hi Guys, I’m slightly confused how surface tension works. I do understand that droplet breakup at 0 will create tendrills and at 1 will burst into separate droplets, I’m just wondering if strength parameter works as a strength value of droplet breakup? So for example if I want to create as much burst to separate droplets should I set "strength to 0 and breakup to 1? or breakup to 1 and strength to 1 as a support value. Hope this make sense, Regards
Hey,
Strength governs the entire surface tension process, for both tendrils and droplets - if you set it to zero, neither of the two would take effect. And the Droplet Breakup itself will serve as a balance between the two behaviors of the surface tension.
Hope this helps, will update the docs as well :slight_smile:
Thanks a lot! that made it clear
