Liquid Emitter not constant
hello, when i start the simulation, it starts beautifully like the middle picture and then in frame 60, the emitter stops(left picture). It starts again but quite weaker like you see in the third picture. Its in frame 100.
Hey,
From the images everything seems fine. What Phoenix version are you using? Can you grab a latest nightly and check how it works with it?
Cheers!
I am using a trial for now - ver. 3.11.00. Dont have access to nightly builds.
Check the sticky topic for nightly builds - it should be fairly easy to get access :slight_smile:
