Liquid not visible in velocity element
Hi ,
i have a simple,. Liquid is falling on an object.
I want to render out the velocity render element. But the liquid is not visible in the channel.
Velocity output is checked for the simulation.
Make sure you have velocity enabled for the Grid as well - there are two velocity check boxes.
Yes, had it checked. It seamed to be the vray blend mat. When i use the standart vraymat only, it is working.
