List of keyboard short cuts?
Afternoon
I have a habit of butting the wrong key sometimes, an all of a sudden things stop working.
At the moment it is the select region and window is not working , and only works if you click on the object.
Does anybody have a set of Keyboard short cuts so I can figure out what I have hit.
Thank you
Phil
You can see all the VFB Shortcuts in VFB > Options > Shortcuts.
Thank you.
Phil
That’s for the render VFB, I am asking generally though.
But thanks all the same.
Phil
In 3ds Max 2025 it is in Customize > Hotkey Editor.
Show some screencaps or video so we can debunk what has happened.
I have shortcut β€œ6” for toggling window/crossing. When I had Keyboard Shortcut Override Toggle activated I Had a complete freeze in Max when pushing β€œ6”: with the toggle activated β€œ6” opens/closes Particle View. It was due to an old Vraypattern demo for VRay 5 which was not compatible with VRay 6, which was also activated with opening Particle View. Strange, but after removing the VRayPattern demo things were solved.
Aleksandar
Thank you ,
I had to reset the defaults to get going again. I am sure I hit a combination of Keys at some point and it just triggers something.
But next time I will. Its a simple things but very annoying I can assure you.
Regards
Phil
