when you work live link and some features you edit in vantage, like hdri rotation, sun altitude azimuth, volumetric fog… then when you render animation live link there should be an option to keep these settings and not switch to default
Submitted on AHA Ideas (VANTAGE-I-34).
Totally agree:
It should be extra windows to select what should be synchronized with sending the scene to vanatge and between every frame. for example:
- geometry (1st load: OPTION / loading between every frame: OPTION)
- cameras (1st load: OPTION / loading between every frame: OPTION)
- textures (1st load: OPTION / loading between every frame: OPTION)
- lights parameters (1st load: OPTION / loading between every frame: OPTION)
- EVNIRONMENT - hdri, sky (1st load: OPTION / loading between every frame: OPTION)
- SUN (1st load: OPTION / loading between every frame: OPTION)
Than creator can decide for example:
I have scene in 3dsmax with a lot of animated options like sun position, geometry, positions, animated texture on the humans or tv, etc, light parameters for timelaps etc.
But I wish to sync in this shot via vantage at first load all materials and geometry, and then only sync them positions (like cars), camera movment and textures. I don’t want to sync sun, hdri- wish to set them in vantage as a static.
That would be super fast way to render different variantions of the animations with vantage in super short and easy way.
And bassicly, it’s gives possibility to render via live link scenes with envoriemnt and sun set in vantage.
If you need more explenation, let me know in comment
Submitted on AHA Ideas by Mat Olszowy.
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
