When I use the initial live link to Vantage, the standalone version of Vantage opens with empty scene.
Are you able to export the scene as a vrscene file with no errors?
Yes the export works with no errors.
Are you “starting the server” (in the Live Link menu) within Vantage?
Then clicking “Initiate a live link” in 3Ds Max?
I couldn’t quite understand the issue. The “standalone version of Vantage” is just Vantage because there is no other version. Are you using live link or a vrscene file? Both were mentioned but they are mutually exclusive.
I use Live Link.
I found a way to solve this issue. I must activate distributing render manually and play the render in the frame buffer, then the live link is active and ready to use.
Ah, I think I understand the initial post now - when you press the Vantage link button it opened Vantage but Max didn’t connect so Vantage stayed on the empty scene. If you open the maxscript listener first it may show some relevant error message. You haven’t changed the live link port in Vantage, right (it should be 20701)?
It looks like Max can’t communicate with Vantage on port 20702 to confirm it is ready to link. Maybe a firewall is blocking it.
