Live Link not working from Sketchup to Vantage (v3.0.3)
Hi guys.
I have updated yesterday Vantage (3.0.3) and VRay (7.2.1) for Sketchup (2024).
Live Link in Vantage from Sketchup is not responding at all.I am switching scenes but nothing happens.
Do i have to install both software again or even in specific order?
Also i want to ask when exporting a .vrscene from Sketchup why the scenes are not appear automatically in Vantage as cameras(like from3ds max for example)?
Thank you.
Do you have AI Enhancer render element in the scene ?
Yes i had the Ai Enhancer.
I delete it , save the scene and now the live link button gives the following message " Something went wrong while trying to start Chaos Vantage. Live Linh failed to connect to : 127.0.0.1:20701.
Same error even on an empty scene (Something went wrong while trying to start Chaos Vantage. Live Linh failed to connect to : 127.0.0.1:20701.) .
Vantage refuses to start through Sketchup Live Link button.
I have reinstall both VRay and Vantage and when hitting the Vantage button in Sketchup i get the error mention before…
Good morning .
I have uninstall and reinstall everything and still i am getting the same error.
I even try the older version of Vantage 2.81 and have the same problem.
Come on guys , its the beginning of the week and still no answer. We have work to do.
Thank you.
Hi again.
To whom it may interested i found the solution.
In Vantage go to :“Live Link /Start Sever on application Start” and check it.
For some reason it was unticked after I deleted the Ai Enhancer render element in the scene.
Thank you.
Hi, George.
Can you confirm if the same issue occurs even with an empty new scene?
Once you remove the AI Enhancer render element, save the project, close SketchUp, and then reopen it.
Can you also please submit a support request from here? Include the topic as well as a link to this forum thread.
Kind regards,
Hi george_gotsis,
How does the Live Link settings look like on your end in Vantage and does it have Start Server on application start enabled? The default IP is 127.0.0.1 and the ports need to be set this way
If the listening ports are not 20701 and 20703 you can reset them to default in t he Change ports dialog:
EDIT: After I posted my question I saw that you have resolved it :smile:
Alexander
Thanks for the answer. All good now!
Your previous post was at the end of the day on Friday and Tashko had a day off today. Sorry about that. Glad your issue is resolved.
Good morning .
Please forgive my tone , but the client was expecting the renders on Saturday and I reschedule for Monday afternoon.
Anyway, as i said before no excuse for my tone.
Thanks again.
