Dear Vantage team
When i am working with cosmos objects in max using livelink and I copy one object (a person or a tree) 1000 instances, then live link starts to get laggish, not fast responding, when navigating from max viewport.
Even without turning off live link navigating in vantage is fast and responsive and as soon as I shut down live link viewport of max starts to get responsive again.
This does not happen with 3ds max geometry, only with cosmos objects
Thanks in advance
Hi digital_technologies,
Since cosmos assets are vrmesh/proxy files you should experience the same if you duplicate a similar size(amount of polygons) vrmesh file and you are in a V-Ray GPU IPR. Can you please check if this is the same on your end?
Alexander
