Hello, I posted a discussion already reported some time ago and for which I have not received an answer.
The problem is that starting a render sequence in livelink from 3ds max, vantage loses the settings and the lighting of the environment mode texture. The sequence is black.
Hi poliedrostudiosrl_poliedrostudiosrl,
Does the settings that are lost are made in Vantage or do they come from Max? When using “Render animation with Chaos Vantage” the scene in Vantage is reset to default from Max with the exceptions of: Post settings(LUT, Bloom), Fog, Render settings. Changes made to lights and environment is reset. If you want to keep the same lighting you have to set it in Max instead of Vantage.
Alexander
