Living Room - WIP
Dear Group
Here is a living room WIP. Used LC/PPT for GI, plus LWF. Illuminated mainly with Vray dome light + hdri. I have also included some light fixtures. I know that it is very noisy This render cooked for 1 hr. In the future I will probably use for GI IM + LC. I tried it for this scene but the results were very weird and very bad. The lamp shade material needs work.
Hm. Dome light mainly used for “off-GI” renderings… 8)
Here is an update. I kow that I need to work on the alpha map for the tree (I wish Vray could properly use png files for transparency). The mapping for the fireplace needs work. Since this scene was already modeled in another application, I may remodel the fireplace within VIZ for the next go around.
Here are the final renders (for now). These renderings are pretty much he same as the others except for some updated materials. There are light leaks present within the bookcases. As of now I have no clue as to how to prevent/eliminate them. Also, there are some speckles and I do not know where they come from. I may update the model to show a skylight option for this room. I am still new to Vray and I have learned a lot during this project. Right now, I am modeling a house that I want to perform full interior and exterior renders using Vray.
S’all for now
Marcus
You might want to take it into Photoshop and try Daforce’s S curve ™
Hope you don’t mind me relinking you image Daforce.
