Hi
I have a lot of old image sequences that needs minor updates, is it possible to load these into VFB and use Render mask to update the sequences with ie. a selected object?
Hi
Currently VFB doesn’t support sequences. What you are looking for is possible but for single file only.
What you can do is to render the object as a separate sequence and then combine it with the older one in AfterEffects, Nuke or another sequence editing software.
Ok, thanks for the info, I was looking for a way to skip that extra comp step.
