load vantage file as configuration only
I will use an example to explain my request:
You work in Vantage with a root vrscene of your project, then you import vrscene VR1 (vegetation) and you save vantage file V1vegetation.
You open new Vantage file with your root scene of your project, then you import vrscene VR2 (people) and you save vantage file V2people.
Here comes the problem:
You open scene V1vegetation in Vantage. This will load your root vrscene plus the imported VR1 scene.
If you then load V2people vantage file as configuration only, in Vantage it will keep in the objects panel the loaded VR1 and it will load additionally (accumulate )vrscene VR2. So you are happy because you have both vrscenes loaded and you can render your film. Then you save vantage file V3VegetationPeople, expecting that when you reopen it , it will load both scenes VR1 and VR2.
Unfortunately when you open V3VegetationPeople vantage scene, you find in objects panel only the VR2 loaded, which is the imported vrscenes of the last vantage file V2 that opened as configuration only.
It would be much more helpful if V3 would contain both vrscenes,
In other words it would be great to be able to import vrscenes both by drag and drop vrscenes in a vantage file and by drag drop vantage files in a vantage file. (even better when you drag drop or open as configuration only a vantage file , it could ask you if you just want the imported vrscenes and cosmos assets or just the configuration settings of vantage or both)
Hope my request is clear
Thanks a lot in advance
Hi digital_technologies,
I have logged your request for loading “combined” vantage files(in your example V3 vantage file)under LAV-1887 and we have an internal fix for it. It will be available in the next release for you to test it. I also have your request for drag-n-drop vantage file popup dilaog under LAV-1884 (as already mentioned in the previous thread drag drop vantage file - Vantage :: Wishlist - Chaos Forum)
Alexander​
