I have trouble when I am rotating the loaded skybox. I have this problem after the latest version.
SketchUp is getting stuck for a while and then continue to work normally and the skybox is rotated. But it is an extremely slow process. Am I the only one having this problem?
Does this happen on all resolutions / skyboxes? If the skybox has a huge dimension that could take longer but it should still be a fracture of a second.
Nope Thomas, I am using the same skyboxes that I used before. Also check/uncheck “use brightest point as sun direction” is also very slow then the previous version
