Loading 3DS Max Render Presets deletes all lights in LightMix channels
Hi, everyone!
I just discovered a serious problem when loading Render Presets - all light sources are completely removed from the LightMix channels, instead of each there is .
I asked my friends to do the same - they got exactly the same result.
Loading 3DS Max Render Presets deletes all lights in LightMix channels automatically?
How to fix that?
Thanx!
This was reported before and it’s a 3ds Max issue, not Corona. If you have some scene objects referenced in your render settings (e.g. LightMix or Render Elements), those references are not saved in 3ds Max Render Presets. You can check that with other renderers. Sorry, but we cannot do anything about it.
