Loading a Vray Preset crashes Max everytime
Never had this problem before going to Max 2010 and Vray SP4. Any fix for this?
Seems to work fine for me on a simple test; can you show me your presets file (or send it to me at vlado@chaosgroup.com)?
Vlado, I solved the problem. I seems to have something to do with Solid Rocks having an ini. file in the same directory as the presets. When I removed the ini file, everything worked fine. Thanks for you response.
Hm, ok; good to know.
