Loading an alembic in vrayproxy looses uvs
​I export an alembic from speedtree, if I import using 3dsmax import, the uvs are all there:
However, if I use a vrayproxy, and I load the same alembic, looks like allt he uvs are broken, both on the preview file, and at rendertime:
Theres any limitation loading alembics using vrayproxys? we need a specific naming convention? Thanks!​
Oh I remember I had this problem before, I need to use the "Force first map channel on the compatibility proxy parameters, XD
