In enscape 2.6 when i check show safe frame and hit render its always lock viewport as custom aspect ratio before finally render, but in the latest update ( v3.0) it showing “adjust and confirm safe frame” dialog instead, which is really annoying to my workflow.
Is there an option to always lock the safe frame view in lastest update (or maybe just disable the confirm dialog) ?
This may be caused by an internal bug at the moment I’m afraid. You can try to re-install our latest preview or revert to our 2.9 release. You may also be able to simply deactivate the “Safe frame” option once 2.9 is installed again, and THEN you can install our preview once more, that should do the trick in disabling this dialogue for good.
With our next preview we’ll also implement a dedicated safe frame button, so you can also just stay tuned for that too. ![]()
