Lock displacement negative shift option
Hi Vlado,
In displacement there is an amount value, and negative shift value. Usually a user has to specify a negative shift to be about a negative half of the amount. What we typically do in maya (also possible in max) is write an expression that takes care of it. Would it be possible to add a lock button to lock the negative shift with a negative half of the amount to the amount slider?
That would be quite handy and simplify workflow for many users.
Yes, someone suggested this before, so we’ll think about it.
+1
Almost as handy as an exposure lock for the physical camera :slight_smile:
b
Yes - I’m definitely with this as well.
Yes. Good to see this suggestion come up again. I’m tired of wiring those spinners together manually.
it gets to be a hassle for sure. Since the way wiring dialogue is made its difficult to navigate to your connected nodes each time you open it.
Also if you have a junior artist figuring things out, it might be difficult for them.
