Lock Noise Pattern - Keeps Unchecking
So this is a big big problem. Whenever I submit my scene to the farm lock noise pattern keeps getting unticked. I am doing animations. Now I keep getting noise flickering. So yeah, this simple thing has now created the whole new vray uselss. Please fix asap as my job depends on animations and this has been a wonderful feature.
Hello, @RedStar
Thank you for your report, we’ll fix this ASAP!
For the little time it finds its way to stable_6.1 nightly builds, you can use the following max script command to enable the Lock noise option for V-Ray:
renderers.current.dmc_lockNoisePattern = true
This will enable the option internally and it will be properly used with your current build. The checkbox will also be accurately displayed in UI with the build containing the fix.
I apologize for the current inconvenience.
Margarita
Hi, the latest stable build has the fix already - Chaos
Tested it on 3ds Max 2023.3 and Lock noise pattern checkbox works.
Worked!! Thank you Vray team for fixing this so quickly. Appreciate this so much!!!
