Lock view of interactive render mode
Im using the latest version now 1.3 with max 2012.
Even if I use the little lock icon to lock the view to my camera the interactive render starts to pick up
the other viewports as I try to adjust the lighting in the scene.
Any ideas?
cheers
Disable the lock, click on the viewport you wish to have locked, enable the lock. Does it work?
So I disabled the lock in maximized camera view.
Started the interactive rendering window.
Enabled the lock still in camera view.
Switched viewport (alt+w) to top view and the interactive window is still switching as well :S
I remember this would happen in certain conditions. Probably if you change the viewport layout or something similar.
Try this:
  1. Disable IR
  2. Restore all the views (press alt+w if you have one view maximized)
    3 When you have all 4 views (or whatever number you are using, but NOT one maximized) right-click on few of them few times
  3. Unlock the lock
  4. Again right click on multiple viewports
  5. Run IR in viewport or floating
  6. Select the viewport which you wish to have locked
  7. Lock the lock
    Does it help?
Bad news it is still doing the same.
I am using a vray physical camera because of the “auto guess vertical tilt” feature.
So I tried it with a standard camera as well but did not made any difference.
Can you send the scene? If it contains some confidential stuff, you can just strip it off the models/textures and send the part with the camera - just please make sure the problem is there. You can send it here or over support: https://coronarenderer.freshdesk.com/support/tickets/new
Thank you for your help but I am not allowed to send anything from actual projects.
This problem is affecting any scene we are working with :frowning:
I think I can send a simple scene that has nothing with current projects.
Cheers,
I had the chance to see if I still have the problem if I use max 2015…
Well it looks like it is a max 2012 bug because in 2015 it works fine.
