lofting help
Why am i getting this behavious from the loft. it looks as though it wants to create the cross section at a tangent to the shape used in that area. if i could figure out a way that it would make a smooth curve id be super happy
Why not just loft the shape you want around a circle?
you mean lathe it? like this?
because im not trying to make a cylindrical object. this is just an example as to how the loft makes a bad surface. i need a smooth curve out of my loft. If i use nurbs U-loft it works perfectly but not with normal loft.
Ah. Just noticed that the original circles were slightly off center.
have you tried a cross section? (editable splice>attach splines> cross section>surface mod?)
cant do that. the good thing with loft is im able to keep each of my loft shapes as an instance of the original shapes. so whatever i do to the originals i can do to the lofted shape
Hi ELf, Why don’t you try a simple loft with a circle and play with the scale in it with adding points with cuves?
because what i want to do will be lofted along a line and will have 20 different cross sections and scale wont work
this is what im working on. each cross section is a seperate spline. see how the loft kinda makes it work on a crappy tangent where as the nurbs is a nice smoth surface
what are the handles for the splines? are the ones that should be smooth set to smooth?
the cross sections are not the problem. its the tangent that being made by the cross lines that join each spline to the next.
Elf,
Here’s a couple things to try just off the top of my head:
1. Are the verticies of your splines welded together?
2. Try fiddling with the interpolation options of the spline.
Hope this helps.
welded? there are 20 different splines there. spline01 spline02 spline03…spline20 they are not part of one mesh. the only time they are joined is when used as seperate cross sections in the loft.
I mean, in each spline, are all the verts welded? Like, are all the verts in spline01 welded together. I’ve had a similar problem before and it turned out there were 2 verts in the same spot that weren’t connected (welded). Make sense now?
yeah, they are all welded. it was drawn as one line and i didnt use a break on any vertex
I cant actually figure out what shape you are trying to achieve..
but try altering the pivot point of the splines - you have to ‘get’ the shapes again to update the loft
ahhhhhh - ok I got what you want - moving pivots wont help - its the interpolation - it sucks but you need to add more intermediate splines and it will force the shape to be smoother
Hey Elf..is that one of them Barbados waves?
What about the Cross Section modifier? You’d still have access to the splines (although they are now all attached as one spline) but you can pull the vertices and the surface adjusts to the new shapes.
each of those splines has a morph modifier on it. thats why i need to be able to use them in an instance way as seperate pieces like what the loft offers
Damn :frowning:
