London project
Heres some images from a recent project that i worked on for a London based development.
More images can be found here: www.iainbanks.com/Barts-Square
nice ones, hell of a lot actually!
Looks great! Well done! :smiley:
Great images man!!
Im going to ask it first :smiley: How the hell did you create such great images!!!
can you give us some insight?? are you using corona sun?
Any tip you can share??
THX in advance
Great work!
Thanks guys, much appreciated.
daniel266: Mostly its all a pretty standard setup using the corona sky and sun except for the dusk shot where im using a peter guthrie HDRI.
To add to the lighting there are IES spotlights throught each shot. Carpets are done using forest pack pro.
wow. The images looks incredible clean.
Can you give us some info about original resolution, passes, etc. ?
Really great work.
Thanks,
Full res is at 5k and each image rendered to between 100-200 passes. Where needed noise was cleaned up using lightroom (mainly for some white walls / ceilings etc)
Hi Ian,
perfect set, love the quality and quantity = )
I had a look at your website though, and love the LA House ! Working on something like that now, very impressed.
Thanks Juraj, yes the LA house was great to work on. Love your studios work also, kept track of it for a while, lovely crumpled beds :smiley:
Good luck at AD#5, was tempted to go again this year but hey they’ve sold out quick.
Impressive!! The staging and lighting looks so amazing, I wonder how long these types of renderings took to render with corona, did you use DR to speed up the process?
Thanks,
At 5k i think typically the images were taking between 2-4 hours each. Rendered using a single pc with dual E5-2680 v2 CPU’s (40 cores)
did you use any portals for the interiors?
Nope, no portals used
is it Hd+pt Or pure PT ¿? When I grow i wanna be like you :smiley:
Perfect and balanced render. Congrats for the good work
daniel266 - Its PT + HD
Thats a beast pc you got there!!
congrats on the ronen feature. great images and love the lighting. :smiley:
Some really amazing images. I love the quality of light and materials, very pleasing on the eye. Im a C4D user and cant wait for Corona to come to C4D. One thing I have noticed though; there does look to be some artifacts in some of the corners like I might expect from vray but I though corona generally handled this sort of thing pretty well - of which it does here but can still see them more here than usual. Render times seem great.
