Long shutter motionblur, only trail behind, not infront?
Ditto this.
Both Max and Maya have standard cameras (i.e. non-physical), and at least for Max there is no Modifier that adds the camera attributes (while in Maya it’s present).
Having global attributes for moblur helps then to achieve things like motion-blurred Ortho views.
What I personally would love to see is one of the minds that created this awesome tool present a way of just doing this, rather than us all spend 3 days and possibly longer
discussing how frustrating it is dealing with the interface :stuck_out_tongue:
If we are missing something then that’s cool - I have always been here to learn best practises, where they exist.
For this particular thing, essentially controllable light trails, there are plugins that do it in various DCCs, XParticles for C4D for example is a modern one, KY Trails I mentioned is an old one that still works.
Still more options in AE, Nuke etc.
Search for this sort of thing and there is practically nothing but these, so clearly there is an issue with ‘real’ mblur that may be difficult to overcome without using ‘fakes’.
However, because we all now want everything to be in one pass, ideally, we all imagine and expect increasingly capable tools to do that.
To my mind, simplistically speaking, it should be a matter of being able to, by coding, dictate where the blur starts and how long it is, as well as how and if it tapers, plus where the brightest spot is.
I’m no coder, so I have no idea how difficult this is to effect…please enlighten me :slight_smile:
I think the same, but there should also be a different way to get the result: By using plausible real-world values for exposure time, F-Stop etc. For long exposure shots, this does not work. Maybe someone of the Chaos staff has an idea how this can be done.
@fixeighted
Do you have the results from Corona at hand?
I didn’t save any files, as it got too confusing whilst trying to work with it in Vray.
The result is the same walking ‘Vlado’ image on the first page, where you can see the settings.
As it turned out, it worked for that in a way, though it also does suffer from some of the same issues as Vray in other situations.
What I loved about it is that it literally took seconds to figure out, whereas I just fought with Vray for 2 days to work out what may or may not work.
The process was exhausting :stuck_out_tongue:
I found this photographic technique which perfectly illustrates the effect I believe, and it’s all in-camera.
I have hope therefore that it is translatable to a 3D camera.
https://www.canon-europe.com/pro/stories/samo-vidic-sports-motion-blur/
Tried to tackle this once again, but failed. It is a mess.
The bias value does not have any effect whatsoever, neither in a free perspective view, nor in a standard or physical camera.
Also, using the same values in a physical camera and in the camera settings yields different motion blur result. A shutter value of 100 frames in the physical cam results in quite a long blur, while using the same value of 100 frames in the Vray camera settings results in a considerably shorter blur. All the other settings were left at default. Could anybody please try to confirm this?
Physical camera with duration of 100 frames:
Standard Max camera or perspective view with duration of 100 frames from the V-Ray Camera Settings window:
Ah ok, so you are using the physical camera rather than the vray one. Not sure what the exact differences are but yes, it’s still unfathomable.
Regardless, from a UI simplicity standpoint, I would argue that any camera options need to be in the camera rollout, as splitting them makes no sense to me - just adds confusion.
The extra ones can be there but they need to be documented properly, as being additional as a utility where other means don’t exist, as Lele intimated.
My simple question is how is there motion blur before an object has even started moving?
All other questions come from that first point I think.
The effect we are looking at achieving, as in that link, is called ‘rear curtain sync’ - it can be ‘front curtain sync’ also - and countless examples are easily found, everywhere, because it’s an artistic choice and a real-world capability.
This surely must be possible in cg, although I can’t find any info on it.
On an only slightly separate note, I wanted to see how camera motion blur affected this example.
I animated the camera travelling from right to left, with the ball stationary.
Camera motion blur doesn’t appear to work at all.
This simple scene is just really bizarre…try it and see…it is totally counterintuitive and exhibits the non-working camera mblur as well as the other anomalies.
What this says to me is that software looks at an animated object…sees that it is going to be in position x at a certain time, then calculates the motion blur and just sticks it on the top, regardless of any other condtions.
So at frame 0, when there is no movement at all, it adds all the blur for the specified time or relative shutter speed.
I want to be wrong…I want to be told I know nothing about real world cameras and that it’s user error. But the more I struggle with it the less likely that seems :stuck_out_tongue:
As usual, I answered at least one of my questions immediately after posting above.
Blur is in front because it is of course capturing the image over a frame range and exposure duration.
So the effect we want is still the curtain sync, which may or may not be possible.
Corona alters the blur very simply with the shutter offset.
Bias in Vray seems to have some effect but it is almost imperceptible.
Vray shutter, blur duration etc. - unfathomable in comparison.
Again, these settings are extremely hard to gauge without the IPR updating accordingly, so I can only hope that’ll be addressed :slight_smile:
Using Corona, it is instant (sorry to repeat myself here) and therefore user friendly.
For each and every setting change in Vray I need to stop and restart the IPR. It’s too frustrating and at this point I pretty much give up trying.
Here are my tests, with Corona. I wanted to do a Vray comparison but I simply can’t replicate it, nor come even that close, which saddens me.
And as mentioned, in any case the camera blur doesn’t work at all, so no comparison possible for that.
I want an AHa! moment with Vray, so help me/us all out here, you clever developers :slight_smile:
EDIT: I just noticed that camera motion blur DOES work, but only using GPU. Still the same non-functioning IPR though - actually worse than cpu as once running it does not update frames even with no changes.
The first image in this post is set up like this:
- sphere moving along a path from the upper left to the lower right, starting at Frame 0 and ending at Frame 100
- the physical camera is rendering Frame 0 with a duration of 100
This image is done the same way, but rendered at Frame 50, still with a duration of 100 frames. As you can see, the trail is starting where the sphere is at Frame 50, and than indeed calculated in advance, “into the future” so to speak. This is an odd way of doing it, and it contradicts my understanding of physics.
All other settings for the motion blur were left at default values.
Yeah it’s too messy and weird for me. As I mention in the other post, if I had a job on including this then I would jump to Corona to do it.
It’s not ideal to switch, but it’s literally seconds to set up and iterate, rather than these days and days of frustrating tests yielding effectively nothing usable/obvious/logical/tweakable…
Forget the last post. After some more testing, this is getting weirder and weirder.
By using different types of cameras, you can get two different results, all for the same settings used. Scene file is attached below.
Same setup as above, sphere moving from upper left to lower right over 100 frames.
Result with Physical camera at Frame 0, 100 frame duration:
Result with standard Max camera at Frame 0, using the same settings as physical camera, but in the Vray Camera settings:
It seems the Physical Camera is sampling ahead of time, while the standard time samples ahead and backwards.
Also, the settings for Interval Center and Bias do not have any effect whatsoever with the Physical Camera. I’m not sure I looked everywhere, but this does not seem to be documented in the docs at all.
This is extremely confusing, to say the least.
sparkler_motionblur_TEST.zip (42.3 KB)
Try this. Dropbox
Your version crahed me so I stripped it of all but the helix and cam and sphere as it’s simpler to share.
I think I have reproduced what Corona does, albeit much more clunkily.
Some nice falloff and a controllable tail length, yet still missing what I would expect, which is the bright light source where it should be in time along the path.
Even when it physically comes to rest it is not fully bright but instead fades up to bright as the tail dies - Corona does this too.
Sure, that can be another layer but shouldn’t it appear on each frame if we’ve forced the blur to be behind the whole way?
Going back to this curtain sync technique, there’s another called dragged shutter which is similar - the image is in focus at the beginning and end with the blur in between.
This is what I believe should be possible.
I notice also that the shutter can go minus but why infinitely?, if, as happens, it can only realistically be maximum -1,
working with the duration (of course in a different panel…grrrr) of the blur.
A negative bias (Render Setup>V-Ray>Camera) should be able to solve your scenario since it would concentrate the lighting towards the most recent movement of an object, whilst the blur from the movement’s beginning would dim out. Note that the bias parameter does not affect physical cameras (not physically accurate), so this solution works only with Free/Target Max native cameras or perspective views. Another solution that may produce the desired effect is through a V-Ray Physical camera’s “Latency” parameter (set the V-Ray camera to Video cam to make it available), because of the video camera’s integrated, but fixed bias.
I don’t think I was using the physical camera, but I’ll check. I did set the bias and interval parameters as high and as low as they would go, and could not get the motion blur to stay behind the object. It works when the motionblur is at a reasonable amount (like 0.5 frames), but not when its at very large values (100 frames for example).
I’ll upload a test scene in a bit. I’m in Maya, BTW.
Seems to work fine in Maya. Make sure there are enough Geometry samples as well. If that doesn’t help, do send the scene to support@chaosgroup.com so we can take a look (or attach one here). Mention this thread in the e-mail along with your V-Ray and host platform versions.
Both @kosso_olli and I have attatched scenes to no avail.
​​​​​​​Is this because it is originally @Buck 's post and you can only reply to his questions?
​​​​​​​I see his query relates to Maya, which may differ considerably from Max.
If so then that’s totally fine and I can begin another post on the topic :slight_smile:
@hermit.crab We did try something like that in Max, it does not work at all. The bias parameter does not have any effect whatsoever, neither with a standard camera, nor in perspective view. Can you please take a look at the scenes that were attached in this thread as well?
@hermit.crab
Sorry for the delay, have been very busy at work.
Anyway, here’s a simple scene. motionblur.ma.zip
The ball is traveling from the bottom to the top in this arc, taking 200 frames to get from start to finish. I have the motionblur set to 100 frames, and 100 geometry samples. I render in the middle of the frame range where the ball is in the middle of it’s path. No matter how I set the settings, I can never get the motionblur to be only behind the ball. Maybe I don’t have the right combination of settings, or maybe it’s not possible?
The exact number of frames is not really important. Other than it being a larger number. :slight_smile:
Here’s a screenshot:
And here’s a photoshop edit of what I am ideally trying to accomplish:
Thanks for taking a look at this, I don’t know if it’s possible or not, but i’d love to be able to do this :-):stuck_out_tongue:
image_60791.zip (10.2 KB)
I’m in Max but this scene is the same.
This uses the video camera, which seems to be the only way I have found to do this.
The information came very late and it’s really not obvious at all.
There is some confusion but it works.
The camera latency parameter is the only thing that controls the effect ‘within’ the camera.
The other settings is what confuses things unless they are known about.
Note that Motion blur is unchecked in the render settings - we don’t need it to be checked for the blur to work in a general sense.
However, crucially, leaving it unchecked means we cannot access the other controls - only the geometry samples.
We do however need to access these controls, as the latency parameter alone will not work - we need to offset the ‘shutter efficiency’
in order to dictate where the blur happens.
In this example, setting it to 1.0 makes the blur be where we want it to be.
This example is perfect to illustrate the general confusion with settings being separated and there not being sufficient info, examples or explanations of
limitations etc. in the docs to come to rational conclusions :stuck_out_tongue:
By the way, I wrote it this way so I can access the info in the future, as I will certainly forget :razz:
Hey right on, I had not tried physical camera with Video, I’ll give that a shot :slight_smile:
