I have a dual opteron setup and P4 setup when I render on the P4 to make the irradience map and ligh cache it takes about 140 mins’ this is for a 4x image. on the faster machiene it take about 15 hours I have not completed one yet and seems to stall at the second pass on the irradience map.
the files are exactly the same. all bitmaps are on the local dirves of each computer. bitmap pager (for both comp) is on under preferences with the following settings:
128
41935
50000
the computer should cut through this rather quickly becuase the settings are on low for the both the irradince map and light cache.
any suggestions, help I have a deadline??
