Longitud Focal
Greetings team, I hope you are very well.
I am writing to you about a problem with the camera that I have had for some time
wear corona.
I wanted to know what I can do about it.
This is a job where the focal length is 50
but when rendering is not what you see in the program.
I hope for your comments
Thank you
That’s a big difference between the two. Can you send us the scene file to look at?
Have the same prob right now!
Update: Cam is correct but the surface deformer is ignored in IR and final render.
Hi, thanks for answering, that work was urgent and has already been delivered.
the camera that gave the problem was removed.
another camera with another focal length and another shot angle was set to avoid
that problem.
But it’s not the first time it happens, neither does it happen all the time
when I have another scene with that problem I pass it
Thank you
Okay cool, of you still want to send the problematic file we can take a look over it. Might be able to help others out too. :wink:
