Hello Guys,
I’m looking for a script…
I want to select objects and create a multisub material (without attaching the objects…).
Best regards…
Hello Guys,
Best regards…
myobjs = $
combined_material = Multimaterial count:myobjs.count name:"combined_material"
for i = 1 to myobjs.count do
mymodifier = (Materialmodifier ())
mymodifier.materialID = i
addmodifier myobjs[i] mymodifier
combined_material.mapenabled[i] = on
combined_material.materialIDList[i] = i
combined_material.names[i] = myobjs[i].material.name
combined_material.material[i] = myobjs[i].material
myobjs[i].material = combined_material
better save your scene first… it adds a material modifier to your selected objects (no errorchecking if anything else than geometry is selected) and creates a multisub with instances of the original material in it. did not put that to the medit, gotta pick it yourself ![]()
regards,
michael
Ok, thank you very much but I’m looking for a script able to do this enevn if there is an existing multi/sub on selected object…
I don’t know if I’m very clear…
Best regards…
Ok here is a quick one. No checking for invalid selection:
sel = selection as array
mat = multimaterial numsubs:(sel.count)
for i=1 to sel.count do
m = materialmodifier()
m.materialID = i
addmodifier sel[i] m
mat.names[i] = sel[i].name
sel[i].material = mat
Just select your objects and it will create the multisub and apply it.
Daniel
I’m assuming you want to create a multi-sub material that contains all of the materials in your selection AND changes the face ID of your objects to match.
As a warning - I am rubbish at scripting, so I simply don’t know how to do what you want without collapsing the objects to a mesh (to change the ID). It could probably be done by adding an edit mesh modifier & making the changes to the face ID’s in that, but again… I am rubbish.
So, here’s my quick script that *might* do what you want… (But will most likely just crash).
Hope it’s of any help!
matstore = #()
matnum = selection.count
mm = multimaterial numsubs:matnum
for i in selection do (append matstore i.material)
converttomesh selection
for i = 1 to matnum do
for s = 1 to selection[i].numfaces do
setfacematID selection[i] s i
mm[i] = matstore[i]
selection.material = mm
Hihi,
this makes things more complicated ![]()
But let’s accelerate development a little bit…
I bet Sushidelic can’t do this in under 30 minutes… ![]()
Time runs…
Dieter
gimme some more minutes, gotta output a fusion comp first ![]()
Sorry it doesn’t work, wath I want to do is creating an only one multi/sub with selected object… And some of this object have a Multi/Sub assigned…
Sorry it doen’t work… He create a multisub with multisub inside…
Best regards…
try this
maxindex = 0
-- first pass
m = edit_mesh()
m.name = "TmpModifi"
for j=1 to sel[i].numfaces do
mtindex = getFaceMatID sel[i] j
if mtindex > maxindex then maxindex = mtindex
-- second pass
m.materialID = maxindex + i
mat.materialIDList[i] = maxindex + i
mat.materialList[i] = sel[i].material
Hello Thanks…
But I’m sorry the script put all the multisud of each object into a new multisub…
On each ID of the new multisub I found others multiSub…
Best Regards…
Yes only after putting the last script did i had an idea on how to make this work. it will take a while to make the necessary changes.
best regards,
daniel
Ok i’ll wait…
For now I’ll do it with my hands… but I hope you can find the answer…
Best regards and thank you to all of you guys…
PS : Sorry my english sucks !!!
Sorry for the delay, but this one should work. The only side effect is collapsing the modifier stack for objects with multisubs.
mtlindex = 0
mtllist = #()
mtlname = #()
mtlcount = #()
mat = multimaterial numsubs:10
-- first pass
if (classof sel[i].material) == multimaterial then
selmtlcount = 0
selindex = #()
tindex = mtlindex
md = edit_mesh()
md.name = "MultMat"
addmodifier sel[i] md
addmodifier sel[i] (mesh_select())
collapseStack sel[i]
facindex = getFaceMatID sel[i] j
found = finditem selindex facindex
if found != 0 then (setFaceMatID sel[i] j (tindex + found))
else
mtlindex += 1
append selindex facindex
setFaceMatID sel[i] j mtlindex
append mtlcount (selindex.count)
for j=1 to selindex.count do
found = finditem (sel[i].material.materialIDList) selindex[j]
if found == 0 then append mtllist (NoMaterial())
else append mtllist (sel[i].material.materialList[found])
append mtlname (sel[i].name + "_" + (j as string))
else
mtlindex += 1
append mtllist (sel[i].material)
append mtlcount 1
md = materialmodifier()
md.name = "MultMat"
md.materialID = mtlindex
append mtlname (sel[i].name)
mat.numsubs = (mtllist.count)
-- second pass
for i=1 to mtllist.count do
mat.names[i] = mtlname[i]
mat.materialIDList[i] = i
mat.materialList[i] = mtllist[i]
Daniel
YYYYEEEEEEAAAAAAAAA !!!
It’s working !!!
Very nice…
Many many thanks…
I put your name on my “wonderful guy’s list” !!!
Just one more think… Is it possible to keep instances ???
Best regards and a big thank you !!!
Instances of materials, or object instances?
Daniel
Sorry Object Instances…
By the way you’ve done an amazing work…
Best regards…
It will take some time but it’s possible.
Daniel
Ok i’ll wait…
Now I can work with the existing one..
It is allready awsome
Ok here it is one with support for instance.
[size=9]
mtlindex = 0
mtllist = #()
mtlname = #()
mtlcount = #()
allsel = selection as array
-- scan for unique objects and create an array with them
for obj in allsel do
instances = #()
instanceObjs = #()
inst = false
instancemgr.getinstances obj &instances
if instances.count == 1 then inst = false
else
--append sel instances[1]
obj = instances[1]
inst = true
for j = 2 to instances.count do
found = finditem allsel instances[j]
if found != 0 then
deleteItem allsel found
h = point pos:(instances[j].pos) scale:(instances[j].scale) rotation:(instances[j].rotation) name:("point_"+instances[j].name)
append instanceObjs h
delete instances[j]
if (classof obj.material) == multimaterial then
selmtlcount = 0
selindex = #()
tindex = mtlindex
md = edit_mesh()
md.name = "MultMat"
addmodifier obj md
collapsestack obj
--maxOps.CollapseNodeTo sel[i] (sel[i].modifiers.count) off
--if sel[i].modifiers.count > 0 then (format "Cannot handle modifiers.\n";break)
--if (classof sel[i])==Editable_Mesh then (format "Not editable mesh.\n";break)
for j=1 to obj.numfaces do
facindex = getFaceMatID obj j
if found != 0 then (setFaceMatID obj j (tindex + found))
else
mtlindex += 1
setFaceMatID obj j mtlindex
found = finditem (obj.material.materialIDList) selindex[j]
else append mtllist (obj.material.materialList[found])
append mtlname (obj.name + "_" + (j as string))
else
mtlindex += 1
append mtllist (obj.material)
append mtlcount 1
md.name = "MultMat"
addmodifier obj md
append mtlname (obj.name)
obj.material = mat
if inst then
for i in instanceObjs do
o = instance obj
o.name = substring (i.name) 7 (i.name.count-7)
o.rotation = i.rotation
o.scale = i.scale
o.pos = i.pos
delete i
-- second pass
[/size]
I glade that i could help.
P.S. Use it at your one risk, i cannot be help responsible if something goes really wrong.
Daniel
