Looping shader node causes maya lockup
Ok so i just thought i would post this…it was an accident when creating a shader node, but i noticed it locked up maya, no crash just locked in an infinite loop i presume :slight_smile: Ive attached a video.
Basically i create a triplaner node with remap plugged in..when the triplanar node is connected to a vray material and i also connect the triplanar into the input of the remap…it locks. This doesnt happen if the triplanar is plugged into, say a maya blinn material.
Anyway, im not expecting any fix or anything, just thought i would post it.
infinite.zip (231 KB)
I have managed to reproduce this problem and logged an issue into our system from our developers to have furter look into it.
You can track it with this internal bug tracker ID: VMAYA-10235
Kind Regards,
Dimitrina
awesome thanks :slight_smile:
