HI, I have been experiencing issues with Vray when Revit crashes. If Revit crashes then i lose all Vray setting and materials and have to assign all materials and any other stetting again. Is there any way to auto save settings for Vray as your progress or each time Revit saves. Or are there any other fixs for this issue. Thanks for any help.
Hi Paul,
Every time you save your Revit project, the V-Ray for Revit settings are saved as well. You can create settings templates using the Share Settings options located in the V-Ray Settings dialog. (More info can be found on our doc page: Chaos Docs )
Regards,
Ana
This seems like either a bad installation, or a bad .vprops file. Does it happen with any project or only with specific ones?
Which version of V-Ray for Revit do you use?
It seems to happen on all projects but no all the time. The version is 3.60.03
We’ve just released 3.70.01. Please download the build from our website.
