I think my question is very popular, but I am pretty sure that every scene has it’s own reason for noisy areas on final renders.
Below is my render.
Summary details and questions:
1600x1200, 180 passes, 2 h 30 mins. My PC is i7 2600, 16 GB RAM - is that normal time or should I look for heavy materials/lights in the scene? What passes number is good with scene like mine?
Lighting. There is VRayHDRI with HDRI map in Corona environment slot. CoronaPortalMtl in the windows. No holes behind the camera. 3 corona spherical lights inside the ceiling light. 2 corona IES lights to the left on the camera (not on the render)
Curtains. CoronaMtl with bitmap opacity mask, transcluency and AlphaMode = “Always Transparent”
Ceiling is white with 0.7 level, no reflection. Walls are Glossines 0.4 and Reflection 55 and with bump
As you may see there is noise in the corners at the top of the table and on ceilings.
Walls are also looks more noisy rather than bumpy with glossy reflection.
Also, colors are unnatural. But most likely photoshop will help.
Will appreciate any advices.
Let me know if you need any info regarding the scene.
Your setup is fine and correct.
I presume you are still on Corona 1.3 and not on the daily releases.
This is 100% GI noise and you can either increase AAvsGI to send sample more GI rays, or… the recommended version… Upgrade to 1.4 daily or wait a week till 1.4 release.
In 1.4 there is adaptivity implemented, which should pickup on that noise and sample the noise away, long before 180 passes. Or even the denoise function which can just outright denoise.
If you need an immediate solution without rerender, you may region render and paste in photoshop. the noisy area.
Also, you can decrease MSI, incase that noise stems from strong rays not being averaged out over time, due to their strength vs the low shadow area samples.
As for the colors, if you do correct PBR workflow with all textures being 50-180 RGB, you will indeed get an ugly washed out look, which requires tonemapping to look nice. But look on the bright side, it’s difficult making a a punchy unrealistic image punchy and realistic, then a realistic and washed out image look punchy and realistic.
Remove the curtains,
Delete the glass windows,
Add a portal on the window
Use use Corona Sky
Override the material with a simple RGB 180-180-180
turn off the lamps and the monitor
Remove the carpet
MSI= 10
Maybe GI VS AA 24
And see what happens. I think you will have less noise
Now, turn on the material, lights etc… And you will find where is the problem.
Applied these steps and got strange result. White dots inside a window.
I thought that something wrong with window frame and replaced it with simple extruded spline which intersects wall so that light cannot came from there.
i would advice just using a regular rectangular light and set it to invisitble instead of a portal, it looks way better and gets rid of the issues you are having
It’s better not to give advise at all, than give bad advise. Putting big light in window opening maybe was good in old days, but certainly not novadays. Putting light source in enviroment, is all that needed for Corona to give great results. Additional sky portals may be beneficial in some circumstances, but not crucial.
actually there are many scenes where putting a light there is needed, in cases where there is little lighting to be used inside a room or when you don’t want the exterior really blown out, using a light portal doesn’t give me what i need most times and since you think its bad advice then i would advise the person who is having the issues to give it a try for himself, it might be bad advice and an old way to work but i am old school and it works for me
I agree with romullus. There is a window + some artificial interior lights. That should be more than enough to make this scene work. The problem here could very well be in the scene setup, or the HDRI, so an additional artificial “window light” would probably only clutter things more.
O i have but i find that i get cleaner n faster renders with a simple plane light in the window, its not accurate as you say but many people dont care as long as i deliver nice looking images, but as you say its bad advice n practice but it hasnt failed me yet. I work this way with all rendering engines though n i know its not accurate but am never really after accuracy 100 percent, once it looks look am game n thats where corona excells, no matter how inaccurate i setup the scene i do in the end get very good results with corona n i do bet many others work this way if they have been rendering awhile
Honestly, CoronaSky (or HDRI) + Sun + Portal is fast enough. tThere isn’t any reason to add a real Corona Arealight on windows to simulate the environment…
I have found an answer for my original question. I took my photo cam, switch it to manual mode and played a little bit.
Finally, found out that the issue was that there was no enough illumination from HDRI outside. And instead of increasing HDRI light power I tuned ISO to 2400 that is obviously too high for the daylight room like that. Same noise you usually see when you try to make a photo in the dark and increasing cam ISO to get something visible on the photo.
