low quality details ??
How can I get a better resolution for this image?
the texture when is far looks funny…
thank you!
Re: low quality details ??
Hello serra, first you have to tweak o your vray settings, What type of settings are you using could you post them, Second if the resolution of the image is more bigger better quality and third what type of textures are you using. :slight_smile:
Hi Davereyes,
the image is 2000x1700 pixel.
I am using GI+LC+IM(Min rate -2, max rate 0 ; Hsps sub 100, Samples 40) and no phisical camera. the texture is just a .jpeg
I have got a good result playing with the Image Sampler:
from
Min rate -1, Max rate 0 (the image above)
to
Min rate 4, Max rate 2
It takes quite long to render…but the result is very good.
I was just wondering if I could play with some other settings :stuck_out_tongue:
thank you
